08-04-2016
08:03
06:18
RobertoME
08-04-2016
08:03
06:18
RobertoME
My zip it won't turn on and it says I have medium battery, I tried taking the battery out and reset it but it didn't work.
Moderator Edit: Upated Subject For Clarity
Best Answer08-04-2016 08:25
08-04-2016 08:25
Welcome to the forums @Maddy22
Try leaving the battery out for a few minutes and be sure the connectors are clean. You can use rubbing alcohol to clean them.
Also, if you have a spare battery, try using that. I know some button batteries don't always last as long as others.
08-04-2016 08:25
08-04-2016 08:25
08-04-2016 08:31
08-04-2016 08:31
