08-04-2016
08:57
06:20
RobertoME
08-04-2016
08:57
06:20
RobertoME
Someone please help me, the site and customer service isn't even slightly helpful and I'm ready to return my fitbit.
I hate the calories burned estimate, I just want it to start at zero when I wake up and show what I've manually burned, it makes it so frustrating having different number starts everyday and having to do the math manual to figure out what I burned, totally regret buying a zip. But didn't want to spend an extra 100 on my first one. When I Google what to do it says go under preferences to disable estimate but my won't do that, I think I just wasted 80 dollars 😞
Moderator Edit: Subject For Clarity
Best Answer08-04-2016 09:03
08-04-2016 09:03
Hello and welcome to the forums @SunsetRunner
There isn't anything you can do to change the burned calories. Everyone's day begins at midnight, no matter where you live or your work schedule.
When you first get your Fitbit, you will see burned calories. The devices begin the day at midnight, so no matter what time you set up, those burned calories will be there. This article on burned calories may help you. click to read
What you're seeing is normal and won't make any difference with your step statistics.
Buying your Zip wasn't a mistake. You bought it to make yourself healthier and keep track of your steps.
08-04-2016 09:03
08-04-2016 09:03
08-04-2016 09:16
08-04-2016 09:16
Best Answer08-04-2016 12:58
08-04-2016 12:58
