01-14-2017
18:06
16:51
LucyAP
01-14-2017
18:06
16:51
LucyAP
Don't try to hold your zip to open it. Put it down on a hard surface such as a table or counter. Hold it with the fingers of one hand while you apply downward pressure with the tool inserted in the groove with the other and turn the cover to the left.
Moderator edit: format
Awesome tips @cadecollie and @Odyssey13! 😉 Nice to see you here @SunsetRunner! This sounds odd, have you tried the suggested tips to replace your Zip's battery?
3. Your old battery can be recycled.
Keep me posted with the outcome! 😉
