01-05-2017 17:36
01-05-2017 17:36
Not keeping track of steps. Reset reinstalled fit bit app several times. Getting to be annoying. Happens for several days.
01-07-2017 03:25
01-07-2017 03:25
Hello @almostthere1, thanks for joining us. It's great to have you on board.
In this particular case, I would like to recommend restarting your Zip once again and then perform an accuracy test to check if indeed the tracker has accuracy issues.
To restart your tracker:
Then, to perform the accuracy test:
If your tracker counted less than 100 steps or more than 100, my best recommendation would be contacting our Support Team. Let them know the steps you've performed so far, I'm positive they will be more than happy to get you back on track.
I hope this can be helpful, keep me posted in case you need anything else!
