My zip does not track the amount it time I spend working in the yard. I spent 2 hours digging weeds in the driveway and then buried part of the telephone wire, that got dug up when driveway work was done, and it registered 8 minutes. How can I get it track my work in the yard?
Welcome to the forums!
If you look at the compare page the zip is not capable of doing this
https://www.fitbit.com/compare
Wendy | CA | Moto G6 Android
Thanks for stopping by @auntiesjd!
My friend @WendyB is right, have you checked the link she shared with you?
Zip will track and display the following:
• Steps taken
• Calories burned
• Distance traveled
• A clock
• The Fitbit Smiley, which highlights your recent activity level
To conserve battery life, your Zip sleeps during periods of inactivity. Zip will go to sleep after approximately 20 seconds if no steps are recorded. Once your Zip is asleep, its display will remain off until moved.
You may want to manually log an exercise for several reasons:
As a friendly suggestion, I'd like to let you know that Zip is most accurate when worn on or very close to the body. Ideal places to wear your Zip include a shirt pocket, bra, pants pocket, belt, or waistband. Try out a few different locations to see what is most comfortable and secure for you.
The Zip is not designed to be worn in direct contact with the skin. Always use the silicone holder when clipping it to a bra or waistband, with the display facing outward. Do not wear the Zip inside your bra.
Let us know if you need further help!
In order to manually log activities, do the following my friend @auntiesjd:
If your iOS mobile device supports 3D Touch, you can also log an activity from the home screen with the Quick Action menu accessed by 3D Touch.
Let me know if there's anything else I can assist you with!
