04-25-2018
		20:52
		16:38
			LucyAP
		04-25-2018
		20:52
		16:38
			LucyAP
When I try to sync my zip icon at top of my iMac screen says dongle is connected-but when I try to sync it tells me to plug in my dongle-yet it puts the data on my sync page if I go to Fitbit dashboard. Any ideas?
 Best Answer08-08-2018 08:22 - edited 08-08-2018 08:22
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi @Janbird welcome to the Fitbit Forums, we're glad to see you here. Thanks for getting back @fredalso.
Thanks for the steps that you've tried to fix the issues with your Wireless Dongle. You can try the next steps to troubleshoot this:
(Mac only) If your computer has Bluetooth, go to your System Preferences and verify that it is turned on. Note that even when Bluetooth is on, the signal can occasionally be weak or problematic. When this happens, plug the wireless sync dongle into a USB port on your computer as shown. If your Mac doesn't have Bluetooth the dongle is required. For more information see: Why won't my Fitbit device sync?
If the dongle is plugged in, your computer should be able to recognize it. To check, on your computer find and click the icon with a Fitbit logo. It is located near the date and time. If you see "USB Dongle Disconnected," try a different USB port.
@fredalso You can uninstall the firewall of your computer and install the Fitbit App again. But if you're having issues with the Fitbit App, you can download the Fitbit Connect version. To download Fitbit Connect click here. If your device is paired to the Fitbit app, it syncs every time you open the app. If you turn on All-Day sync it also syncs periodically throughout the day. If you sync your device with a computer and Fitbit Connect, it syncs automatically every 15 to 30 minutes when the Fitbit device and computer are nearby, and the dongle is plugged in.
If you're getting a specific error message, please let me know.
 Best Answer04-26-2018 16:54
                              04-26-2018 16:54
Welcome to the Forums @fredalso! Thanks for sharing your experience with Fitbit Connect. Upon checking with Support I was able to see that you have a case with them.
The best option at the moment is to continue working with them. I'm sure that they can help further with this and get you back on track in no time.
Catch you later! 🙂
		04-28-2018
		10:03
		17:10
			LucyAP
		04-28-2018
		10:03
		17:10
			LucyAP
amazingly my zip and dongle are talking to each other again, so it wasn't the dongle as Fitbit support told me. Fantastic end to my nightmare-but Fitbit could hire people who speak good English for their customer support staff, by the way thanks Fitbit.
 Best Answer04-30-2018 17:12
                              04-30-2018 17:12
Thanks for your reply @fredalso! I appreciate your feedback about Support. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience. Please keep me posted if you have more questions or need further help.
Also, I'd like to encourage you to join us at the Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 🙂
08-02-2018 08:43
08-02-2018 08:43
This is happening to me too! The dongle is plugged in but for some reason it does not register.
Is it broken? Do they wear out?
 Best Answer08-07-2018 08:13
08-07-2018 08:13
trouble started again the fitbitlogointhedock shows the dongle is connected-but when I try to sync it says dongle not connected-but all info gets loaded just as if it synced because I can go to Fitbit .com dashboard-all info is there-something screwy---what is it?????can't load latest app -it just says an error occured when trying to instal. anyway you say that the latest app is just to work with latest models of Fitbit which I don't have and don't want. mine is an old zip! what the hades is going on??????. have revceie no help so far that hassled the problem- new dongle didn't help installed new dongle and it worked fine for about a week then went back to not working
