i've had a problem with my zip not consistently syncing with my phone/account. Some days it will sync once or twice, some days it doesn't sync at all. It used to sync all the time.with my Galaxy S8+. I end up having to restart my zip (take the battery out) and then it will sync after that but it still will not consistently sync ( i do have the sync now and all day sync functions enabled. This has been going on for a couple months now. Was wondering if any else has had this problem or knows how to fix it?
Thanks
Dwight
Thing is they don't offer a comparable clip in version to even upgrade too. It sucks, cause no competitors offer a good alternative either.
I hate wristbands.I hate the feel. Often have to take off because they interfere with work and chores. Much easier to forget to put back on, oppose to Zip discreetly clipped to cloths. Blue light screen wake me out of sleep.
I bought a new zip, had this same problem, returned it, and am now having the problem with this zip as well. It only syncs when I remove the battery. I have an android watch and don't want to wear a Fitbit watch as well. I'm so frustrated!!
If you have an Android phone with Android 9 or later, there's no point in calling. The only long-term solution is to continue removing and reinstalling the battery when you want to sync. They'll probably have you try a dozen different things before eventually getting to that fact.
The Zip doesn't work properly with Android 9 and, since it's a discontinued product, this is probably as good as it gets unless new code for one of their supported devices happens to fix the issue. After 10+ months of this problem, that seems pretty unlikely.
Called yesterday, no sync with pixel 3xl. Fitbit solution was remove/replace battery. Kept old Samsung phone so I can sync.
Best AnswerMy Fitbit hasn't updated since 7/8. I have taken the battery out and replaced and it still isn't syncing. I too hate wrist bands and prefer the pedometer, so not sure what to do if it won't sync.
So after much reading, the ZIP is done. It's not on the website anymore which is why i'm assuming it isn't working anymore. I read through here the Inspire can replace it. It has a clip you can buy separately. I just placed my order so lets hope this works now. If it doesn't i'm done. I'll find something else. Fingers crossed.
Best AnswerI was able to finally sync when I used the dongle with my PC. I had been trying to use my phone this whole time and that wasn't working. Hope everyone else has some luck too.
