I noticed my time was off so synced my Fitbit and it reset to zero and still didn't reset the time correctly. Took battery out and cleaned inside Zip and when I resynced again it again reset to 0 and I had taken steps during that time. Also showing my battery is low. Batteries last either a week or months. What gives. Here it is 745pm and I have lost all my steps!
Hi @Gradgrl75, welcome to the Forums. It's great to have you here. ![]()
Wow, thanks for checking all those details you've done a terrific job. I can tell that you took some time to review the correct troubleshooting. I was just wondering if you also confirm if the metal contacts inside of your Zip aren't bent, take a look of this post.
If that's the case, the next step would be checking with our support team, I can give you a hand with that. Keep me posted.
