05-13-2018
18:59
08:11
LucyAP
05-13-2018
18:59
08:11
LucyAP
My old zip broke and I now have a new one so how do I get this new one to sync?
05-13-2018
20:01
08:10
LucyAP
05-13-2018
20:01
08:10
LucyAP
Hello @mackaygb
All you need to do is set up the new Zip as a replacement for the old one, using your existing account. When you do that, all your history is there to view and you keep going with the new device where the last one finished. Be sure to sync the old Zip one last time.
Keep on stepping!
Moderator edit: added link
05-13-2018 20:14
05-13-2018 20:14
05-15-2018 08:09
05-15-2018 08:09
Awesome help @Odyssey13! Welcome to the Forums @mackaygb! So good to hear that @Odyssey13's tip worked and that you are back on track.
I have gone ahead and marked @Odyssey13's as an Accepted Solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member facing the same questions or issues as you. You can read more about Accepted Solutions here.
I hope to see you around more often! 🙂
