Sip battery
I lost my fitbit when I moved then found it about 2 months later. The battery was dead so I bought a new one but nothing happens after I put it in. Help please!
4 REPLIES 4
Well, replacing the battery should give it a restart, but, just in case, you might try following these restart instructions again .
Hello @Cat2398 welcome to the Fitbit Community! It's great to have you here 🙂 Thanks for the cooperation @Julia_G Woman Wink  @Cat2398 I would suggest to review the troubleshoot on this link: http://imgur.com/a/l1KwH if your Zip is not turning on after this I would recommend to contact customer support and let them know with details the troubleshoot you performed so they can assist you.
Let me know how it goes! 🙂
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
Find, rate and share the best memes and images. Discover the magic of the Internet at Imgur.
Help! I tried using a coin to open my Fitbit zip battery door, but to no effect. However, I did bend it, and now it will not open. I asked customer support on Twitter and they said to try using a coin, however, that is how my tracker broke in the first place. I was wondering if there was another way or if I could qualify for a new one? Anything would be appreciated thanks
Hello @APBCC welcome to the Fitbit Community! It's great to have you here 😉 You can visit this thread as some users have shared how to open the back of the Zip. If this doesn't work please contact customer support so they can review your options.
