12-08-2020 05:55
12-08-2020 05:55
After recent app updates, our Zip devices are AGAIN depleting the battery in LESS THAN 2 Days ! This was an earlier problem, solved by turning off ‘All Day Sync’. Now, it is back on & no way to disable it. Ready to throw these away & start tracking on our iphones !!!!!!!!!!!!!
iIs anyone from FitBit’s new owners LISTENING ? At all ? Ever ?
Best Answer01-21-2021 10:22
01-21-2021 10:22
I agree and this has been an on and off problem even when it was still being marketed. After a couple of weeks with 2 - 5 days battery life when this package is gone I will be giving my zip up even though I love it. There is nothing else available from Fitbit that interests me. I don't want a device that I wear on my wrist. I have a watch that I like.
Best Answer01-21-2021 10:58
01-21-2021 10:58
Best Answer01-22-2021 08:40
01-22-2021 08:40
Best Answer01-26-2021 12:26
01-26-2021 12:26
Hey @Cooper2008 and @Gfkdrobi,
Check your battery connections, they could likely use some tweaking to maintain a better connection. Mine lasts for months at a time.
(not my original picture)
Regarding "is anyone from Fitbit listening", possibly, but as this is a member-supported forum, where users of the devices try and help one another, so you're barking in the wrong place, however, you can reach Fitbit by clicking this link.
Best Answer01-27-2021 07:41
01-27-2021 07:41
Best Answer01-27-2021 09:43
01-27-2021 09:43
@Cooper2008 you're welcome. Regarding "looked at the connections but what specifically am I looking for", I'd included a photo, if you can't see it from your phone, maybe try from the computer, as it will show the tabs that you'll want to slightly pry. A small swiss-army style knife or even a paperclip can help to move them out. What happens is over time the metal wears and pushes away from the battery, creating a poor connection, and by correcting them, works well, provided there aren't other issues with the tracker. I had these same problems prior to readjusting mine. Regarding Fitbit mods, I've seen them here occasionally. Recently one was bumping posts from 2018 for no clearly stated reason, it was rather weird. They're likely more active in the forums for currently supported units as they're able to guide people to warranty services, etc. Possibly, they only engage here when someone flags a post. TBH, I've gotten lots of great tips and tricks here from other community members in the past several years and never once bumped into a conversation with a moderator, FWIW.
