Hi @n0rg, nice to see you here! ![]()
Thanks for trying these steps in order to connect with your Zip. The Wireless Dongle should be in a range of 15 to 20 feet of your Fitbit. If this is not working as it should, please disable other Bluetooth connections when not in use as it might be interfering with the signal. In case that the syncing issue continue check this article: Why won't my Fitbit device sync?
Give it a try and let me know how this works.
