04-22-2018
04:26
14:45
LucyAP
04-22-2018
04:26
14:45
LucyAP
I am going overseas for 5 months and will not be using my Fitbit for this time - apart from removing the battery, is there anything I should do?
Best AnswerOk good! That is the only one you can remove the battery from. That should keep it in the best condition you can. I will move this thread to the Zip Board (it is currently in Coach)
Helen | Western Australia
Which model of fitbit do you have? On most you cant remove the battery. Lithium batteries dont like running out of power and sitting empty for long periods. It would be better for it if you could arrange to keep it charged while you are away, but I know that is not always possible.
Awesome help @NellyG! Thanks for stopping by @hypo.11! I have gone ahead and marked @NellyG's as an Accepted Solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member facing the same questions or issues as you. You can read more about Accepted Solutions here.
I hope to see you around more often! 😉
