09-28-2017 17:38
09-28-2017 17:38
Is there a way to convert the number of miles on a stationery bike to steps on my FitBit Zip? I biked 16 miles today, but my FitBit doesn't show near that in steps. If I manually convert the miles I biked, it would be over 33,000 steps. Thanks!
Best Answer09-29-2017 00:52
09-29-2017 00:52
I'm afraid not. Fitbit strictly consider steps to be only counted when you actually take steps - it doesn't convert other activities like cycling, swimming, weight etc
The assumption is that as the various challenges are based on steps made then it would not be fair unless steps meant steps.
09-29-2017 06:53
09-29-2017 06:53
Have you tried attaching to your shoe while cycling?
Best Answer10-10-2017 17:57
10-10-2017 17:57
Awesome help @SteveH and @Playthru! Thanks for stopping by @TristanADCH! If you remember the amount of steps taken you can manually log them. To do so you may follow this post.
However, as @SteveH mentioned above, only steps recorded by your tracker, MobileRun or MobileTrack are counted toward challenges and goals.
I hope this helps, keep me posted! 😉
