06-13-2016 09:56
06-13-2016 09:56
16:00
03:31
06-14-2016
16:00
03:31
Thanks for taking a break from stepping to visit the Community @Shaylalala. Your Fitbit Zip battery should last up to 6 months before needing a replacement. I would recommend checking out your Zip contacts by following @vomitofthemind's instructions. If the contacts are obstructed this might cause the battery to drain quickly. Additionally, a restart to your Zip as @Odyssey13 stated, might help you out.
The all day sync option shouldn't drain your battery that fast.
06-14-2016
16:00
03:31
06-14-2016
16:00
03:31
06-16-2016 22:05
06-16-2016 22:05
Best Answer06-17-2016 13:01
06-17-2016 13:01
Thanks for joining us @Zip_davis. Your Zip should reset your steps automatically every day at midnight. If yours is not doing it please be so kind to contact Customer Support. They will be happy to investigate your case and might provide further assistance.
Keep up the super stepping. ![]()
06-20-2016 05:32
06-20-2016 05:32
Best Answer06-26-2016 15:33
06-26-2016 15:33
Thanks for the update @Zip_davis. Hopefully your Zip is working as intended from now on.
On another note, you are welcome to visit the Discussions board. You can find many different interesting topics to join out there.
Hope to see you around more often. ![]()
