Thanks for joining us @SVBanks! This sounds odd. To ensure that your tracker is working correctly, please restart it. Then, check this post on How to Fix Syncing Issues.
I hope this helps, keep me posted! 😉
Best AnswerThis happened to me a while ago. There are some things you can try:
you can restart it,
or you can delete it from you're acount then reconnect it to you're acount
or you can request a new Fitbit zip from Fitbit, only if all else fails
