02-10-2023
07:17
05:52
02-10-2023
07:17
05:52
Can not open zip back with tool. Coins, flat screwdriver etc. damage back opening. Any other suggestions
Best Answer02-15-2023 09:56
02-15-2023 09:56
Hi @Anniebd over the years, I've seen a few people with this problem and I'm not sure there is an easy solution. Many who posted said they needed to break the cover piece in order to get to the battery, but there was no way to put it back in. Can you use a tiny flathead screwdriver, one used for eyeglasses to pry the back cover up? If it breaks, you can always put the zip into a little pouch. There are Zippo lighter pouches with a clip that you can wear like the Zip and it would protect the missing back portion. Sorry there isn't an easy answer to this for you.
Best Answer02-15-2023 10:19
02-15-2023 10:19
Best Answer02-15-2023 10:32
02-15-2023 10:32
That was a brilliant way to get it open. I have a Zip using friend, so that tip may be needed one day. You can buy other cases for the Zip from Amazon in a variety of colors, too.
Best Answer02-15-2023 11:04
02-15-2023 11:04
Best Answer02-15-2023 12:24
02-15-2023 12:24
My Zip friend says that only Energizer 2025 batteries from Amazon seem to work. Walmart Energizer batteries, the same size don't like to work. Evidently some Zips are as picky about their batteries as some of us humans are about our fitness devices!
