12-28-2020
12:39
04:39
12-28-2020
12:39
04:39
It got engaged again during an update and draining my battery like crazy. I just want to sync on demand.
Best Answer@LeVuong your post has really nothing to do with the subject of this thread and the subject of this board.
I'm afraid Fitbit has removed that option. They say:
"To improve your experience with notifications, syncing, and firmware updates, we removed the option to turn off all-day sync from the Fitbit app. When your phone is near your Fitbit device with Bluetooth turned on, it periodically syncs with the Fitbit app to update your stats and download available firmware updates. More frequent syncing rarely, if ever, noticeably decreases your device’s battery life"
Taken from: https://help.fitbit.com/articles/en_US/Help_article/1877.htm
I have found a way to turn off auto sync! Go to phone settings -apps - fitbit - permissions - then turn off location access. You will.need to turn it back on when you want to sync but it's easier than turning off the Bluetooth which you probably use for other devices 🙂 hope this helps
Open the Settings app to review your phone settings. Confirm or adjust these settings:
Set up the notifications you want to receive on your wrist. Make sure your charged Fitbit device is nearby.
On the other hand, in regards to the All-Day Sync, turn it off:
Hope this helps!
