09-29-2017 14:18
09-29-2017 14:18
This gadget drains batteries faster than any other device I've had. Thank God I received it free if not, I would take it back and get my money back!!
09-29-2017 15:26
09-29-2017 15:26
I set up new zip on Tuesday night and had low battery warning Thursday...
I bought this new zip because previous one, whilst still working, was needing a new battery every 2 weeks or so.
I'm constantly concerned about battery life all the time. Rapidly losing faith in Fitbit for which I used to be a strong advocate.
09-29-2017 23:53
09-29-2017 23:53
My original Fitbit was given to me as a gift and worked fine for several years. The battery seemingly lasted forever but probably for 6 months. However towards the end of its life I seemed to be replacing the batteries (2025) after increasingly shorter periods of use to the point that I dated the battery and noted replacing them weekly. I called the Helpline and someone on the other end advised me to lift the one electrode (the one at 12 o'clock) and straighten the other (at 4) which didn't work. Eventually I broke the electrode at 4 after fiddling with it repeatedly.
I decided to buy a new Zip and lo and behold I have the same problem with the battery indicating after two weeks that it needs replaced. What's to do? What's to do? No diagrams available to indicate that I may have placed the battery incorrectly and not good advice from the helpline. Anyone have any useful advice?
09-29-2017 23:55
09-29-2017 23:55
I agree wholeheartedly. Thanks for sharing. See my post under jfialkovz2.
MJF
10-03-2017 09:05
10-03-2017 09:05
If not for my job, I won't be using a zip. This device is not even worth the price it sells, even if it's half off or discounted for any reason. Battery life drains fast for a tiny little device. It's insane! It should not even be on any fitbit product lines. Samsung gear is great but my workplace, for some weird reason does not take samsung devices.
10-03-2017 10:43
10-03-2017 10:43
Help with this issue would be great. I went so far as to buy a second Fitbit. When I originally started having the problems with the battery, I thought it must be because it was a couple of years old. I get about 13,000 or more steps in a day so maybe that was too many. At any rate I started using the new Fitbit, I immediately put a new battery in assuming the other one had expired its six-month life. It's been 2 weeks and my Fitbit is already indicating that my battery is low. New Fitbit and new battery. Any thoughts or solutions would be awesome.
10-03-2017 11:27
10-03-2017 11:27
10-03-2017 11:28
10-03-2017 11:28
10-04-2017 00:27
10-04-2017 00:27
I am having the same issue as some of the others. I have had my zip for a number of years, (almost 5, I think), and up until a couple of months ago, I only had to change the battery about every 6 months. Now it tells me it needs to be replaced again, and that would be 3 in less than 3 months. I had been thinking about buying another, but perhaps that might be a waste of money. I use the zip every day, and have been very satisfied with it until recently. It has me puzzled why a new one would drain the battery quickly, but that is what some others have said, and I have no reason to doubt them. I am not sure that I will bother to get another.
10-04-2017 09:01
10-04-2017 09:01
10-04-2017 09:07
10-04-2017 09:07
10-04-2017 09:26
10-04-2017 09:26
10-07-2017 04:46
10-07-2017 04:46
I just changed the battery last week and low battery warning is on already! I am not happy with this Fitbit at all. Can anyone suggest a different simple tracker?
10-09-2017 11:02
10-09-2017 11:02
Don't get a Fitbit One! We're having the same battery drain issues. Mine lasted 2 hours today!
10-09-2017 11:37
10-09-2017 11:37
10-09-2017 12:21
10-09-2017 12:21
@FitTXDC wrote:Don't get a Fitbit One! We're having the same battery drain issues. Mine lasted 2 hours today!
Well I guess we'll just have to keep looking. The battery that I put in my Fitbit last week had to be changed on Saturday I believe that was four whole days. I'm going to try changing the battery size to the one you suggested. Can't hurt to try. I'll let you know how that turns out meanwhile I guess we'll be looking for a new type of Fitbit
10-09-2017 14:41
10-09-2017 14:41
Fitbit replaced my previous Zip with a new one. However, the battery lasted only a couple weeks. Going to hold off until Fitbit has a solution. batteries are not inexpensive
10-12-2017 16:54
10-12-2017 16:54
My battery is only lasting a few days. I can't keep spending 5 bucks a pop! Is this a common problem?
10-13-2017 01:09
10-14-2017 18:07
10-14-2017 18:07
