Usually it means that the battery is running out, but recently mine was doing this despite it being a fairly new battery (only put new battery in two weeks ago) and the app saying battery was at 85%. Yesterday my Zip just suddenly stopped working entirely, even with a brand new battery and making sure the battery contact points are connecting properly. I'm wondering if maybe after a while the Zip just stops working...
Best AnswerUsually it means that the battery is running out, but recently mine was doing this despite it being a fairly new battery (only put new battery in two weeks ago) and the app saying battery was at 85%. Yesterday my Zip just suddenly stopped working entirely, even with a brand new battery and making sure the battery contact points are connecting properly. I'm wondering if maybe after a while the Zip just stops working...
06:00
06:28
AlvaroFitbit
09-25-2020
06:00
06:28
AlvaroFitbit
Thank you so much for this reply and for taking time. Odd that website in icons did not simply have it listed. I was told by Chat person to take it out, put it back, and then if that did not help (it did not) to replace it . Then the new one in 2 days got same code. I am trying one more and then will just try a new Zip I think. I am going to try all the possibly bad batteries in new Zip before I throw them out just in case it has nothing to do with battery. (I am very frugal and those batteries are not that cheap!) Good luck with your plight too. Thanks. Peggy
Moderator Edit: Personal info removed
Best AnswerThis was helpful and the ONLY person who took time to reply so doubly appreciated that. nice person. Peggy
