05-05-2018
14:01
17:07
LucyAP
05-05-2018
14:01
17:07
LucyAP
I have been wearing a Zip since at least 2014, probably 2013.
I have never worn a watch in my 52 years and so I am not comfortable with them as I did try a Charge at one point.
I am compulsive checker, and don't have the patience for my phone to catch up, so I take it off multiple times a day when on my daily walks.
This of course causes wear and tear on the halters and I would go through from two or three a year.
The first few years, Fitbit sent me a new halter for free.
Then it started to come with a minimal cost, not sure $4 of $5.
Once again my halter is about to come apart -- and they do not seem to last as long either -- and when I checked on getting replacement, I saw it now costs $14.95.
$14.95 for a piece of rubber and a metal bendable clip.
I think that is a bit excessive.
05-05-2018
19:27
10:10
LucyAP
05-05-2018
19:27
10:10
LucyAP
Hello @rink23
There are a lot of third party Zip cases that you can find at Target, Walmart, Best Buy and other places. You can also purchase them from Amazon and the cost varies. If you have Prime, you can get free shipping on it.
I'm sure you'll find something that works for you.
19:27
10:10
LucyAP
05-05-2018
19:27
10:10
LucyAP
Hello @rink23
Thanks for the help @Odyssey13! Welcome to the Forums @rink23! I appreciate the thorough feedback for the Fitbit accessories. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
Please notice that since these accessories are not made by Fitbit and they may not have the same Wear & Care standards, this is why we don't recommend them.
Thanks for your understanding.
Best AnswerLucy,
I really enjoy my Zip. I am obsessed with my Zip.
My problem is with the price of the replacement clip.
The first couple of years, and as I explained in my post, I check it a lot so it gets wear and tear, I got sent replacements for free.
Then it was $4-6 for the replacements.
Now they're $14.95.
I found a Amazon site where I got one which looks like it will work just fine for $5.
Also, I seem to be going through the halters -- all of which up to now I have purchased from Fitbit -- quicker than in the past.
So if this recently purchased one falls apart more rapidly than Fitbit purchased ones, I'll go back to buying them from Fitbit.
Until than I am going to go with the cheaper price.
Thanks for the reply @rink23! I appreciate your thorough feedback about the Fitbit accessories. This has not gone unnoticed and be sure that I will pass this along. Still and all, I hope you keep enjoying your Zip as much as we do and please keep me posted if you need more help or if you have more questions.
Catch you later!
