08-02-2018
18:01
08:37
YojanaFitbit
08-02-2018
18:01
08:37
YojanaFitbit
I have used my zip for about 4 months, but today it want syn with my phone or computer? Acts like it can't locate my zip?
Hey there @RHAWK! Welcome to the Family! ![]()
Thanks for choosing the Forums to troubleshoot the issues with your Zip. You have an excellent advise there! If you found any of those steps useful let's mark @SteveH post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions.
If this didn't resolve your inquiry, you can check more steps in this article: Why won't my Fitbit device sync?
If you need more help, I’ll be more than glad to lend you a hand with that!
08-08-2018 08:36
08-08-2018 08:36
Best Answer08-02-2018 23:34
08-02-2018 23:34
As it's not working with your phone or computer the issue is probably with the zip. I would try restarting it by removing the battery for 10 seconds. Give this a few tries as it sometimes doesn't work.
08-08-2018 08:36
08-08-2018 08:36
