04-09-2016 06:03
04-09-2016 06:03
Best Answer04-09-2016 08:53
04-09-2016 08:53
Hey there @Zip-newbattery welcome to the Community!
Don't worry, sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. So verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing.
Let me know if that works!
Best Answer04-09-2016 13:59 - edited 04-09-2016 14:03
This is what I did. I replaced the battery for my zip' a few days ago. I got zero response from my zip...
I was going to go for a 3 miler walk n run so i checked the Battery ;opened it up and found on the battery a sticker put there in the factory for good reason, no doubt... alas.. i peeled the sticker off; redloaded the battery tap... tap its working fine. now.... I hope your solution is that simple..
DanBrown
Best Answer04-11-2016 05:13
04-11-2016 05:18
04-11-2016 05:18
11:07
10:03
FatimaFitbit
04-11-2016
11:07
10:03
FatimaFitbit
Oh! Great @Zip-newbattery.
If you have any other question or concern regarding your Fitbit, don't hesitate to post me back!
I'll be around.
Best Answer04-11-2016 16:50
04-11-2016 16:50
I can't even figure out where the door is to put the battery inside.
06:00
10:04
FatimaFitbit
04-12-2016
06:00
10:04
FatimaFitbit
Best Answer04-12-2016 07:17
04-12-2016 07:17
06:03
10:04
FatimaFitbit
04-13-2016
06:03
10:04
FatimaFitbit
