07-06-2018
16:08
10:39
YojanaFitbit
07-06-2018
16:08
10:39
YojanaFitbit
I have tried to force sync my ZIP now for 3 hours and it will not sync. I have turned blue on and off, uninstalled the app and reinstalled the app. I am afraid to disconnect ZIP because I don't want to lose my 20,000 steps today. I tried pairing and I get the error couldn't pair with ZIP check your ZIP settings...It worked yesterday and nothing has changed...SOOOOOOOOO Frustrating. I have had Fitbits since 2012 and it seems be getting to complicated to get anything to work....:(
Moderator edit: Updated subject for clarity.
Hi @CannotSync7 and @cleeS1948! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community @Coopchan! ![]()
Thanks for the steps that you already try to fix this syncing issues @Coopchan, if your Fitbit Zip was tracking and saving in its memory those 20,000 steps; it should remain there even if you disconnect it from the Fitbit account. If you're still having syncing issues with your Zip try the next steps to fix it:
If you encounter any issue let me know with details, so I can further assist you. But I'm pretty sure that these steps will do the trick. It's important to confirm that you syncing device is listed here and is up to date.
Note: Make sure your phone and Fitbit App are up to date. And for Android phones take a look of this tips for syncing from @ErickFitbit! ![]()
Let's give it a try and please keep me posted! ![]()
