07-13-2018
09:31
10:39
YojanaFitbit
07-13-2018
09:31
10:39
YojanaFitbit
Hello all,
I just changed my battery in ZipFit, and the "blue tooth" is on...but ZipFit is still not capturing activity.
What do I need to do?
Thank you for the help,
Lisa
Moderator edit: Updated subject for clarity.
07-17-2018 10:38 - edited 07-17-2018 10:38
Hi @LisainVentura, thanks for stopping by! Thanks for joining this family, hope you like what find here! ![]()
Thanks for the details on your post. If your Fitbit is not tracking your steps or other data, it may be fixed by restarting your tracker. To restart your tracker:
Note: Restarting your tracker as described below reboots the device. Note that restarting your tracker does not delete any data. Your Zip should now be restarted. You will see your tracker's version number,
followed by a series of Fitbit Smilies. When you tap your tracker, it should work
normally.
Hope this helps.
Best Answer07-17-2018 10:38 - edited 07-17-2018 10:38
normally.
Hope this helps.
