09-09-2016 05:58
09-09-2016 05:58
I've had my zip since May 2014. Recently, it's stopped counting steps. Time and smileys still work, so it's not a battery issue. Is this fixable, or does it mean my zip is dead?
09-09-2016 07:48
09-09-2016 10:02
09-09-2016 10:02
09-09-2016 15:36
09-09-2016 15:36
09-09-2016 15:38
09-09-2016 15:38
09-10-2016 04:27
09-10-2016 04:27
Same thing has happend to mine. Did you get an answer?
09-10-2016 04:30
09-10-2016 04:30
I've put in two new batteries to make sure that they weren't duds. It does not track steps. Everything else seems to work fine. This is my second Fibit and I'm a little nervouse about buying another tracker from fitbit. I was looking a the Fit Bit Charge 2 but will need to do more research to determine if there are problems with it.
09-10-2016 04:32
09-10-2016 04:32
09-10-2016 10:15
09-10-2016 10:15
09-11-2016 04:53
09-11-2016 04:53
09-11-2016 05:58
09-11-2016 05:58
09-28-2016 05:00
09-28-2016 05:00
Hi everyone, it been a while this this issue was mentioned here. So I wonder how it goes @sumo and @bookw0rm? I offer you my apologies for not answering sooner but I see you were assisted by @Ozzie65.
In case the issue persist if the Zip come and goes as you mentioned @bookw0rm. Probably is a shortcut but it might be also a bad battery connection. Sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing or simple by daily usage. So the best is to verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. For additional information check this post from @Rich_Laue.
@sumo If you want information about the Charge 2 please visit our web site to learn more about the features of the new tracker: https://www.fitbit.com/charge2
If the issue persist or you have more questions, let me know. I'll be around.
09-28-2016 11:57
09-28-2016 11:57
I've also been talking to technical support; the conclusion is that it's toast. The problem is either the battery connection or the the cover; it comes and goes. They've offered me a discount on a new one, since it's out of warrnaty; waiting for payday.
It keeps count intermitenly, and, when I'm not near the computer, loses large chuncks of time. Since it's also doubling as my watch, not good. Hope to be able to replace it soon
09-28-2016 15:31 - edited 09-28-2016 17:50
@bookw0rm thanks for the update! I'm truly sorry to hear about your buddy. I believe a 25% discount is a great alternative to try out a new Fitbit tracker. You can stick to the Zip which is pretty cool or dive into an ocean of possibilities by checking out other Fitbit trackers.
Thanks a million for your patience and efforts on troubleshooting this issue. See you around!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
