07-22-2018 03:03
07-22-2018 03:03
Hey guys.
My zip isn't giving me correct readings. It'll show I've only done 10906 steps but phone pedometer shows 13500. It is also showing the incorrect calories burnt as well. Please can someone advise me as I feel let down
07-22-2018 09:53
07-22-2018 09:53
this morning my Zip's battery was showing low, so I put a brand new battery in & that battery showed nothing at all, so I put the old battery in and it was working up to a minute ago, I hand mowed my front lawn came in to sync tracker and it still showed low battery, then all of a sudden in the middle of syncing, it showed full battery and 0 steps, when I actually had 1245 steps, what's up with that??? I lost my steps??
07-23-2018 11:03
07-23-2018 11:03
Having the same issue. My steps are going up but then they keep resetting back to 4,084.
07-23-2018 12:46
07-23-2018 12:46
07-23-2018 13:53
07-23-2018 13:53
07-23-2018 17:17
07-26-2018 03:23
07-26-2018 03:23
07-27-2018 08:05
07-27-2018 08:05
Hi everybody! Thanks for posting your questions and comments here in the Forums.
Thanks for all the attempts on trying to help your little buddy. If your Fitbit is not giving you the correct number of steps or calories, please restart it and try to make sure the battery is in a correct position, since it might be loosing contact affecting the functionality of it.
You can also clean the place where you put the battery using a cotton swab. Make sure that the little metal piece that makes contact with the battery is not bend or rusty too.
If you keep having issues after trying this, please let me know so I can request a new case for you and our team will be helping you out with this.
Keep me posted.
Best Answer07-31-2018 03:50
07-31-2018 03:50
I checked my battery housing post, inserted new batteries, which show a full charge. However, my steps are not showing accurate on my device or phone. Sometimes, my device shows nothing- yet my numbers on my phone bounce back and forth. Please help!
Best Answer07-31-2018 11:04
07-31-2018 11:04
08-03-2018 08:11
08-03-2018 08:11
Thanks for trying those steps and confirming that information @dlhink and @justjannie!
As you keep having issues with your Zip and the steps that you've tried are not working, I've requested to our support team to create a case on your behalf. You should soon receive an email from Customer Support at the email you used to register with the Community forums.
I'll around in case that you need anything else!
