11-21-2018
07:54
08:15
YojanaFitbit
11-21-2018
07:54
08:15
YojanaFitbit
My fit bit is not syncing steps on the computer (IOS). Battery is fine, I checked. There was a period of time when I was recovering from injury and I was not using it. Now it's not connecting with computer. I've deleted info and reentered the app on my phone. Still no luck. Help
Moderator edit: Updated subject for clarity.
Hi @trudylynne1 thanks for jumping in. Welcome! ![]()
Thanks for trying those steps. Please verify each requirement before moving on to the troubleshooting steps.
If your device still won't sync, try the steps below:
You can also use your phone to connect. Please if it is listed here and before to try to connect with your phone delete the Fitbit Zip from the Bluetooth on your computer. Then try the following:
This should solve any syncing issue that you're having, please keep me posted on the resolution! ![]()
Hi @HonoraKelleher ! Thanks for trying those suggestions. It is always a pleasure take care of our happy Fitbitters. Please feel free to come back at any time, our desire is to take care of each one of the members of our family.
Keep stepping around in the Forums! ![]()
Thanks for reaching out @Jodeerae, welcome to the Forums.
Sorry for the time that I took to response. If you're still having the issues that you described you can find some steps here: Why won't my Fitbit device sync? You can send an screenshot of what you can see from your end if you keep having issues with your Fitbit app after trying those steps.
See you around.
