12-20-2018 19:13
12-20-2018 19:13
Over the last few years, I have lost 3 Fitbit zips and just last week lost my Fitbit flex. The clips that come with zips always end up falling apart, typically the rubber ends up ripping and the zip falls out.
The flex I just kept in my pocket hoping to eliminate the clip problem. But it turns out that the flex slips out of your pocket easily. (Best guess is that is fell out in a bathroom or a dressing room).
Has anyone found a solution for a clip type Fitbit that doesn’t fall apart or get lost? I don’t want a wrist band, I gesture way too much for it to be accurate.
12-21-2018 13:30 - edited 12-21-2018 13:31
It's nice to see you here @Caseylara, welcome!
Thanks for sharing your feedback with us. Sorry to hear what happened to your last trackers. Have you checked this article: What should I do if I lose my Fitbit device?
At this moment we don't have more options than the Fitbit Zip, I was making some research and was able to find this request from other users: New updated clip on tracker. Please cast a vote for these ideas and leave a comment to show support for them. Since this is a newly launched feature, we're always interested in ways to improve the product! Thanks for your feedback.
Both clip and wristband trackers are very accurate, you just need to take into consideration some tips. If you don't find your Fitbit, let me know so I can request a ticker for you.
Let me know if there's anything else I may assist you with.
Best Answer12-28-2018 18:40
12-28-2018 18:40
Lost zip. Clip issues. not very tight. easy to slide on and off
Best Answer01-06-2019 14:20
01-06-2019 14:20
Hi @Vtwin88 nice to see you on the Forums, Welcome!
Sorry for the time I took to respond. Thanks a million for sharing your feedback with us. Did you find the suggested steps useful? I'd like to know if there is anything else I can help you with.
I'll be around.
