04-25-2019 09:50
04-25-2019 09:50
my Zip won't sync to my phone or with my computer with the dongle.
Best Answer04-25-2019 11:13
04-25-2019 11:13
If you are trying to sync to a device running Android 9.0 (Pie) don't waste your time, it will not sync. The only way to get it to sync is by restarting the Zip (removing the battery) or syncing to another device that runs an older version of Android. Do a search on this forum and you will see that you are not alone.
04-25-2019 09:59
04-25-2019 11:13
04-25-2019 11:13
04-25-2019 11:57
04-25-2019 11:57
I had a feeling that might be the case. Thanks!
Best Answer05-03-2019 00:06
05-03-2019 00:06
Do you have to pull the battery every time you want to sync, or just once to get it back to being paired? *
Best Answer05-05-2019 18:34
05-05-2019 18:34
What about Mac El Capitan? I replaced the battery and it now is sort of stuck and the time is not right...
Thanks,
Dawn
Best Answer06-15-2019 08:39
06-15-2019 08:39
Thank you for your input. I spoke with Fitbit yesterday and they really did not have an answer 😑
