11-06-2017
19:10
09:41
LucyAP
11-06-2017
19:10
09:41
LucyAP
I can not get the back plate off to change the battery. My battery keeps dying. The groove is getting worn down to nothing. Can I buy a replacement cap.
Best Answer11-10-2017 09:40
11-10-2017 09:40
Thanks for taking a break from stepping to visit the Community @Jeanette74! At the moment there is not a back door replacement. However, to further assist you I've created a Support Case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
Best Answer11-11-2017 22:14
11-11-2017 22:14
Have lost the back hard disk. Where can I buy another..? Thanks?!!!!
