Zip stopped working
My Fitbit is blank. Worked fine for four months. Replaced battery two weeks ago. Zip is now blank. Please help!!
1 REPLY 1
Hi @Janekeeper welcome to the Community! Sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. Please verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here: http://imgur.com/a/l1KwH
Let me know how it goes! Cat Happy
Heydy | Community Moderator, Fitbit
Find, rate and share the best memes and images. Discover the magic of the Internet at Imgur.
