04-23-2016 16:09
04-23-2016 16:09
Best Answer04-24-2016 04:11
04-24-2016 04:11
It's great to see you around @Griffew. Your Zip will count steps while driving depending on what type of road you are driving through. This article explains how your Zip works while driving and how to negate those steps. This is a good idea to have a good track of your steps.
Hope this information helps, keep the stepping up! ![]()
Best Answer04-24-2016 09:24
04-24-2016 09:24
Best Answer04-25-2016 04:11
04-25-2016 04:11
Regarding the steps @Griffew, you can create an activity called "driving", which will overwrite your calories, steps, etc, for the period you were driving. Or, you can download an app called "DriveBit", which you can activate while driving and will create an automatic driving activity for you.
Fitbit doesn't pass your calories burned through to your MFP account. Fitbit sends the calories you burned and MFP adds them, if those calories are over what you set to be your "typical" day, you told MFP that you typically burn a certain amount of calories but Fitbit has noticed you have done a bit more walking and estimates that you will end the day with certain amount of calories burned.
Happy stepping! ![]()
