07-10-2019 17:35
07-10-2019 17:35
My zip has not been working for over two months now and still no fix. I keep reading they are working on the problem or they are not working on the problem so I really don't know what is going on. I really like my zip tracker . I wish they would just fix the problem. Don't know if that is going to happen.
Best Answer07-11-2019 03:53
07-11-2019 03:53
It's been over 10 months for many of us...
The Zip has been discontinued and they've stopped monitoring this forum (as per the announcement at the top). It's not likely to get any better from this point forward. I doubt very much that they're actively working on anything related directly to the Zip since they've dropped the device.
All you can do at this point is remove and reinstall the battery each time that you want to sync. It sucks, but this is what FitBit has left us with.
Best Answer07-12-2019 01:39
07-12-2019 01:39
Well from everything I am reading the zip tracker is out and they don't care about all there loyal customers that still have and love there zip. So I guess it's time to trash mine and I will not be getting a new one from Fitbit . I hope I am wrong and the problem is fixed but I don't think so to bad I really like my zip tracker. I don't know why they can not just fix the problem...........
Best Answer07-12-2019 13:47
07-12-2019 13:47
The iOS app tells me there is an update: "Update Tracker"
After doing so, I push "Next" then it finds my Zip, starts the update, then says:
"Something went wrong. There was an error while trying to update your device."
Please advise. My Zip version is 72. All other features work.
Best Answer07-15-2019 00:02
07-15-2019 00:02
So I am reading all different things about the zip tracker. What I need to know has the zip been discontinued and is it not being monitored anymore or will the problem be fixed sometime soon an answer real soon would be greatly appreciated.. thanks for any answer. My zip stopped working three months ago and I have tried everything that was suggested and nothing has worked.
Best Answer07-15-2019 00:03
07-15-2019 00:03
Best Answer07-24-2019 12:49
07-24-2019 12:49
My zip stopped syncing in the beginning of may after I had an update to my phone which is a Samsung Galaxy s8 . What I would like to know has the zip been discontinued and replaced with something else or is the problem going to be fixed. Can anyone help with a answer. I have tried everything that was suggested to try and fix the problem but nothing works and I tried several times please help with a answer of what is going on.
Best Answer07-26-2019 17:40
07-26-2019 17:40
My zip will not sync and has not since the beginning of may. Has the zio been discontinued and is it being monitored anymore. Is anyone trying to fix the problems.please answer. Thanks
Best Answer07-26-2019 19:03
07-26-2019 19:03
Hi @Anthony10
Yes, the Zip has been retired and there are a few new styles of Fitbit products released. The Inspire has an optional clip, so it's the most like your Zip.
Restarting your Zip, turning off and on bluetooth and logging in and out of your account may be helpful. If you check the Fitbit store, you won't see the Zip listed anymore.
07-29-2019 14:56
07-29-2019 14:56
Thanks for your help. It worked this time.
07-29-2019 18:09
07-29-2019 18:09
Awesome news @rubyred1952 and thanks for taking time from stepping to post that for us!
