05-31-2022
18:17
06:29
05-31-2022
18:17
06:29
My fitbit won't sync on my mac computer. I've turned blue tooth on and off as the help site says and it does nothing.
06-17-2022 07:54
06-17-2022 07:54
Unfortunately Zip won’t work on windows 11. So you might won’t to go back to windows 10. Then open the Zip app make sure your toggle is connected and your fitbit nearby click on your profile click on the zip click on the arrows in a circular this should do the trick
Best Answer06-18-2022 11:23
06-18-2022 11:23
Darlins, Im using iPad and having problems syncing.
06-18-2022 13:37
06-18-2022 13:37
Best Answer08-28-2022 18:23
08-28-2022 18:23
I can’t get my zip to sync to my iphone SE. I turned Bluetooth off/on. Ditto phone. Deleted/reloaded app. When I try to force a sync it the “star” keeps turning. It worked until earlier today. Zip battery is full. Very frustrating
