11-08-2018
20:08
11:18
YojanaFitbit
11-08-2018
20:08
11:18
YojanaFitbit
Yesterday my Fitbit would sync with my device galaxy note 9 but today it will not. Did something change?
Moderator edit: Updated subject for clarity.
Hi @Pagilbert nice to see you here on the Forums.
Thanks for trying to sync with your Zip. We're currently receiving feedback about different devices that are not in the list of tested devices. And our team is working hard to add as many devices as they can but In this case, as this model is not there; we can't assure the Fitbit App will be working flawless. This means that you might be able to download the App to see your stats, log food and exercises, but they won't be able to sync to receive call or text notification without having some difficulties.
You can use a different devices to sync for example a computer or a different model of phone. Some users have reported that they are able to connect after checking some requirements and following some steps.
Requirements:
I would recommend following the steps below:
Make sure to check your phone Permissions and leave Location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
Hope this helps, let me know if you have questions.
