It used to synch without any problems before the update.
I need to remove the battery for ZIP to synch.
I`very tried closing the application and Bluetooth.
It will ONLY synch one time after the battery is removed and reinserted
I even called support.
Does it have something to do with the update.
I've had my ZIP since April of this year..
something to do with the update?
Are they working on a fix?
I am having the same issue. I even took the battery out & my device still doesn't sync. It's upsetting as I need this device for a class I am taking in school and this is such an inconvenience & so frustrating.
