06-19-2017
14:03
19:48
LucyAP
06-19-2017
14:03
19:48
LucyAP
To whom it may concern;while changing the battery in my Fitbit the compartment cover virtually split into two pieces.I was wondering where I could get a replacement or if you could send a replacement.
Thank you
Moderator edit: format
Best Answer06-19-2017 23:49
06-19-2017 23:49
Unfortunately, customer support do not monitor these forums. You'll need to contact them via:
You may also want to edit your post to remove your email address as this is a public forum.
06-21-2017
17:44
19:49
LucyAP
06-21-2017
17:44
19:49
LucyAP
Hi!
I would call Fitbit tell them what happened and see if they will send you a new cover for the battery compartment. They're usually very accommodating. I'm sure they will be glad to do it.
Best Answer06-27-2017 19:55
06-27-2017 19:55
Awesome help @SteveH and @EatingRight! Nice to see you here @spudinsky! I just wanted to step in to know if you finally contacted Support and if they were able to help.
I look forward for your reply! 😉
20:34
15:46
LucyAP
06-27-2017
20:34
15:46
LucyAP
Hi,everything has been resolved,thank you.
Best Answer06-29-2017 16:32
06-29-2017 16:32
Thanks for the update @spudinsky! It's good to hear that you are back on track. I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more! Give it a look! 😉
Best Answer06-30-2017 09:28
06-30-2017 09:28
