11-14-2016 15:51
11-14-2016 15:51
My computer died and I had to get a new one. I can't get the fitbit icon for syncing that I had on the old computer. I now have Windows 10 and I have tried to download the app, but have not be successful as yet. Any help on finding the icon and getting it pinned to the lower tool bar?
11-15-2016 00:54
11-15-2016 00:54
As you are now on Windows 10 you have a couple of options.
To continue to use the fitbit connect software via the icon on the PC dashboard you need to go to www.fitbit.com/setup and download and install the software again. Make sure that you select "PC" before clicking on the download button.
You can also use the fitbit app from the Windows app store which means that you don't need to software or the icon. What problems are you having with this?
11-18-2016 04:49
11-18-2016 04:49
11-21-2016 12:11
11-21-2016 12:11
Great to have you in the Community @trekrider60 🙂
Were you able to download the app/software? How did it go? Are you able to sync your Fitbit to your computer?
If you need any kind of help, let us know. We'll be happy to help you out!
11-21-2016 17:26
11-21-2016 17:26
11-22-2016 06:31
11-22-2016 06:31
yay! Great to hear that it's all fine now @trekrider60. Thanks for getting back! 🙂
Anything else you may need, we're here to help!
