11-16-2016 12:57
11-16-2016 12:57
Hello there. My Fitbit Zip battery is low. I can't seem to find instructions for what to do. You'd think there would be a user manual online for all the devices. I went to the forums and saw comments both about charging your FitBit and changing your FitBit battery. Not sure what to do.
Best Answer11-16-2016 13:45
11-16-2016 13:45
Welcome to the forums @bre7ezy
Here is the manual for your Zip - click
The Zip takes a button battery, CR2025. I usually buy mine in a two pack and save it for when it's needed.
Let us know if there is anything we can do for you.
Keep on stepping!
11-16-2016 13:45
11-16-2016 13:45
Keep on stepping!
11-23-2016 14:05
11-23-2016 14:05
@Odyssey13 thanks for posting the Zip manual! I'm sure this will help other Fitbit users with the same question. Way to go! ![]()
@bre7ezy let us know how did it go! We'll be looking forward to your new comments! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
