08-21-2019 21:35
08-21-2019 21:35
my zip fit bit has stopped syncing 2 days ago with my iPhone. it is recording the steps etc properly and the battery is full. when trying to sync a message tonight said "not connected to the internet", bluetooth, cellular data is turned on.
Best Answer08-22-2019 07:07
08-22-2019 07:07
Solution found:
needed a phone call to learn that you need to be away from all other devices connected to wi-fi when performing the following:
take battery out, wait 10 sec., re-install battery.... this reboots zip fitbit
turn off bluetooth, back on
open fitbit App on phone and ta-da it works!!!!!
Why is this included in the on-line help?
Best Answer08-21-2019 21:45
08-21-2019 21:45
Apparently mine stop thinking yesterday as well it only showed me having 451 steps and I know I had more than that and today it won’t sync at all. Hopefully someone can help us.
Best Answer08-21-2019 21:52
08-21-2019 21:52
I don’t know if you saw the other post but I did what they said. I restarted my phone and then I took the battery out of my zip and put it back in. Caught the rest of my steps for yesterday and my steps today. Hope it works for you!
Best Answer08-22-2019 04:20
08-22-2019 04:20
I did everything IAM supposed to and it still says tracker not found on my phone
Best Answer08-22-2019 04:21
08-22-2019 04:21
I hope so it still says the same thing
Best Answer08-22-2019 04:23
08-22-2019 04:23
I need the same thing it work for a day but now again it's doing the same thing
08-22-2019 07:07
Solution found:
Best Answer08-22-2019 12:52
08-22-2019 12:52
08-22-2019 16:16
08-22-2019 16:16
I did that to and worked for awhile but now IAM back to the same thing
Best Answer08-23-2019 14:18
08-23-2019 14:18
I did everything it worked for a bit then the same thing so then I call customer service and they put me through some steps and again worked for a bit and the same **ahem** this is so frustrating
