I have the fitbit zip, and I will be buying an android tablet in the next month or two. Unfortuantely, none of the tablets I'm looking at are on the supported device list. My daughter's Kindle Fire HD is not listed, but it works just fine. So I was wondering, is there an unofficial supported device list? The tablets I'm currently looking at are the ASUS Zenpad S8, the Lenovo Tab2 A10, and the Samsung Galaxy Tab A. I would really like to get a tablet that will sync to my zip, as I don't turn on my computer every day. Oftentimes I will go a week before turning it on, and it doesn't sync with my phone. Is there a way I can find out if it will work with any of these tablets before purchasing? Thanks!
Best AnswerNot really. Most of the time you can't even download an Android app that will work on an unsupported device. The tracker will hold 7 days of detailed data and an additional 23 days of summary data if that helps.
Best AnswerInteresting, thanks. My phone is not supported, but the app works fine. I just have to sync to my computer first, then can see the results on my phone.
