08-15-2017
15:49
12:42
08-15-2017
15:49
12:42
@Carol1018 welcome aboard. Thanks for joining us!
Please note that your Fitbit Blaze battery can last up to 5 days. Because battery life is affected by use and other settings, actual results may vary. Additionally, rapid battery drain can be caused for several reasons. Take a look at these tips to improve your Blaze's battery life:
Hope this helps. Keep me posted!
Oh and btw, you might have noticed that I moved your post to help keep the community organized. Good luck! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
