Battery indicator
Twice this week my Fitbit flex has shown medium battery and totally died. Not life shattering, but if you wear your tracker 23 1/2 hours a day like me and have just returned from a 30 minute walk- you know what I'm feeling. Arghhhh! Do I need to do handy dandy reboot on Fitbit, is this a problem with app or what's the dealio?
1 REPLY 1
Welcome to the Fitbit Forums @HeddaJ! I have seen some instances where the device is charging incorrectly; you should double check the charging instructionsBattery life is affected by various factors and settings. Take a look to the tips for preventing battery drain. If the issue persists, please be sure to reach out to our Support Team. I know that they're always happy to listen to your experience and provide different options for you, if needed!
I hope this helps. Let me know the outcome.
