03-25-2016 04:05
03-25-2016 04:05
Best Answer03-25-2016 10:07
03-25-2016 10:07
Found the solution! I got on Live Chat w/a FitBit agent, who solved my problem. Here's the chat: Agent Paola: First, plug your charging cable into the USB port and insert the other end into the port on the back of your Charge. Your Charge will begin charging. Now, press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V30") Me: ok it says V110 Paola W.: Now please let go of the button Paola W.: And unplug your tracker from the charging cable Me: did that Paola W.: Alright, your Charge should now work normally. (it did)
03-25-2016 04:21
03-25-2016 04:21
How are you trying to connect? Fitbits are unusual in that the connection has to be made via the fitbit app rather than the phone's bluetooth settings.
Best Answer03-25-2016 04:26
03-25-2016 04:26
Best Answer03-25-2016 09:25
03-25-2016 09:25
Best Answer03-25-2016 09:42
03-25-2016 09:42
I'm having exactly the same problem! My Charge has been syncing just fine ever since I received it at Christmas, but both yesterday and today it refuses to sync; its data doesn't appear either on my iphone5s nor on my fitbit.com account; the fitbit app on my iphone just keeps saying "looking...." even though bluetooth is connected, my fitbit is fully charged and in range. What to do???
03-25-2016 10:07
03-25-2016 10:21
03-25-2016 10:21
Best Answer03-25-2016 10:44
03-25-2016 10:44
Best Answer03-25-2016 10:50
03-25-2016 10:50
Best Answer03-29-2016 11:54
03-29-2016 11:54
I tried this, but it didn't work for me.
