01-18-2022 08:06
01-18-2022 08:06
I have a Charge 5 and an Aria 2 set of scales.
The Aria shows me my Body Fat % when I get off of it but for some reason this is not transferring to the fitbit app or dashboard where it just says hidden.
I previously had a Charge 3 and it used to record Body Fat on the app - so what has changed and how can I set it up to do so?
Many thanks in advance.
Best Answer01-18-2022 08:21
01-18-2022 08:21
Does your weight show on app?
Best Answer01-18-2022 08:32
01-18-2022 08:32
Yes it does - that seems to work fine it just shows -- where body fat should be.
When I look at the Aria on the dashboard it says Hidden under body fat but doesn't have an unhide option.
Best Answer01-18-2022 10:06
01-18-2022 10:06
Sorry but I'm no help on this one. Hopefully someone else will jump in.
I'm not using Charge 5 but wouldn't think that would not be the issue; I don't recall seeing this problem before. And I don't know of any setting to hide body fat, though I have seen requests to be able hide weight.
