Welcome to the Community @Ben_s. If you are not seeing the tracker's tile, I recommend verifying if your tracker is paired, if it is not paired follow the Setup Procedure, also please check that your phone is a Compatible Device. Once you setup the tracker, you can follow the Call Notifications process.
Let me know the outcome! ![]()
