04-18-2017
15:10
09:08
MarcoGFitbit
04-18-2017
15:10
09:08
MarcoGFitbit
This is the third time my iPhone and charge 2 won't sync and the charge 2 is mia on my Bluetooth list. Help!
Moderator Edit: Clarified Subject / Format.
Best Answer04-19-2017 09:41
04-19-2017 09:41
Hello @staceyleanne, thanks for joining us, it's great to have you on board! ![]()
If your Charge 2 is on the list of paired devices on the Bluetooth settings of your phone, that means you've enabled Notifications, not necessarily that the tracker is syncing with your phone. As you mentioned the Charge 2 is not syncing correctly, please follow these steps:
If your tracker is still not syncing, let's try to set up your tracker as a new device to reset the connection between the Charge 2 and your phone. Don't worry, this won't delete any of the information previously stored information.
To set up your tracker as a new device:
I hope this can be helpful, give it a try and keep me posted in case you need anything else! ![]()
