08-13-2019
13:23
06:08
AlvaroFitbit
08-13-2019
13:23
06:08
AlvaroFitbit
So I downloaded the app update and now my charge 2 will not charge up. It worked fine before I updated. 😢🙁
@Sbrown0728, it's great to see that you've visited the Fitbit Community!
Let me help you with your Charge 2 not charging. The app can't affect the physical battery on your device. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best AnswerI cleaned it and have chargers it in different things for over night. And still nothing. The battery just flashes with a ! Point flashing in the middle of it.
Best AnswerFollowing mine is doing the same thing.
I wish they would get it fixed. Didn’t have this problem before the last update
