Welcome to our Community my friend @Diablogt! It's great to see you around!
I'd like you to know that you will receive a low battery notification whenever your battery is lower than 20%. What's important to note is that the battery level displayed in the Fitbit App is the battery level from the last time you synced your tracker. Syncing your tracker will update the battery level in your app to the current level.
Hope this helps! Let me know how it goes! ![]()
Best AnswerI wish there was a way to see an accurate battery level. From what I can tell there is only two ways to check the battery level.
One being plug it in and see where the charge reads to which is very inconvenient but seems to be the only way to get an accurate reading.
The other way being syncing with the app and checking it's reading there but there only seems to be three states it reads there, Full, Medium, and Low. Which is pretty vague at best.. I would love to see an actual bar like when charging or a percentage on either the app or the device itself (I use a Charge HR).
